I have a 92 lx 5.0 hatch. The trans in the car was shot but everthing else worked fine. Car still started idaled fine everything, Well friday I put in a new bog-warner t-5 in the car and bolted everything back up and tryed to start the car and nothing. So then i looked back over everthing and relized i did not hook back up the sencor on the side of the trans that wont let the car start unless the clutch is pressed in so I pluged it up and then tryed to turn the car over and i get this weird buzzing sound for the motor compartment. Not your normal clicking from the starter if the batt is dead. Neg terminal gets hot if i keep trying to turn it over. So I fugured maybe ut was a bad ground. Took sand paper to the block and replaced postive and neg cables. Took a look at the wiring diagram every thing on the starter and starter solenoid (or starter relay) on the fender wall is hooked up properley. So then I went and got a new batt and new starter and still the same thing. Just some odd buzzing from under the hood, never heard this on any car before, Its not like a arcking sound or anything. The only other thing I found out is when I jump the starter solenoid on the fender wall with the key turn in the on postion (car should start) I dont hear anybuzzing just the starter click forwards and then back when i take the screw driver off. This has me really P.O. I have build 4 motors with not one problem I can do top ends rebuild bottem ends, Almost anything, I am cant believe i cant figure this out. Could I need a new sensor thats on the side of the tranny that I pulled of me out one??? could that be it?? or do i have a short some where. Has any one every had this happen to them??? Please Help
Sgt Jacob Pope
24th MEU
Camp Lejeune NC
USMC
Sgt Jacob Pope
24th MEU
Camp Lejeune NC
USMC
But at the same time I know that shold not have a diffrence starting the car. Its just a whole nother problem that I will have to fix after I get the car started
I will try the test with the multi meter just have to barrow one from a buddy.
