work on motor or drivetrain, got 1000 and want SOTP!
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
I want to get motor work done so i can have a gateway open later, or gears and converter. BUT people tell me to ditch my AOD and get a c4, telling me i will blow my OD out, they suggested getting a juckyard c4 and building it. How much would that cost, rebuild and VB and converter etc ( pretty much making it performance oriented and better than the AOD.
Or they suggested an intake to get things started.
I was going to build my longblock but i figured it would take a LONG time and i want some gains NOW or in the near future.
So its b/w motor, gears and converted or new tranny.
WHICH ONE?!!??!?!?!
I"M SO CONFUSED!
Scratch the C4 idea (only 3 gears)...only if you were running it at the track would I consider that.
Gears/converter/with some traction will give you a very nice drop in E.T's at the track and a better SOTP feel.
If this is your daily driver I might suggest going with 373's...
An intake like a Cobra/Performer intake wouldn't be a bad idea...and to go along with that you could get some 1.7 Crane/Ford RR's and maybe a 65mm TB and bigger MAF like a 75 or 80mm MAF.
But gears will give you the best bang for your buck at this stage...
How many miles you got on your car? If it don't smoke that is a good sign. A leakdown/compression test will let you know where the condition of your motor is at and whether you should think about rebuilding.
FYI, but a DSS 306 base block (rebuilt 302) is $1,500 bucks which isn't bad if your bottomend needs work.
www.dssracing.com
i am at 131k, my motor seems to be running Really good, no leaks or anything, nothing has gone wrong.
How would a cobra or trickflow work for my car, i'm probably not going to see over 300 hp.
