Would upper leak cause this??
vpap1
109
OK, I have a 90 GT speed, track heat stage 1 HCI, 17 degrees timing, 80 mm maf, 75 mm TB, pullies, ac delete, smoge delete, 2.73's 160 degree t stat. I have whistle coming from the rear and under the upper intake. Sprayed carb cleaner to find it and havent so far. Its and air leak and all the vaccum hoses check out. Anyways ... I reset the base idle to 950 rpm. Plugged in the IAC again then adjusted the tps to .98 volts. I started her up and she stuck right at 1000 rpm. I started driving her around town and when coming to a stop, I press in the clutch and the idle hangs and stays at 1500-1600. She has alot of power and leaves nothing on the table. At the begining of the drive she was not at peppy when idling at 1000. Is this weird or is it all just vaccum leak and when I ix it i reset her and she will be rock solid at 1000rpm??
thanks
V
i dont know what the vacuum set up is on the track heat but i had a whistle back there and the hard tube from my fuel pressure reg was broke...is the pcv in the stock location back there? check that..just ideas..
I had just got a new fuel pressure regulator and had to make a longer hose. Its not leaking from what i can see. And the pvc valve i had even wraped some teflon tap on to make sure she is snug. IDK man but thats for the suggestions
V
What brand throttle body? Does it have a small pilot hole drilled through the blade?
"Setting" the TPS does nothing. The EEC references the voltage at startup and adjusts its range from there. So long as the TPS is good (read: within tolerance) then there's no advantage to having it set to a percieved sweet spot.
I'm guessing that your TB is a PP based on your "setting" the TPS voltage.
Where is the throttle stop set to? It sounds as if the stop may be too far out.
Also look at the throttle linkage itself where it conncts to the throttle body to ensure that it's not hanging up on anything.
Check all the ducting between the MAF and the throttle body to ensure it is air tight.
the TB is a Trickflow unit at 75 mm
the throttle stop i set was at 1000 rpm with iac disconnected
the linkage has no kinks in it i have disconnected the cruise to make sure of this
the ductig is air tight as well.
I guess what my question is, is that would a upper manifold leak cause the idle to hang at 1500 even if the base idle was set to 1000?
thanks
V
Potentially, yes. Short of having an AFR meter to see if you're running lean, you can try turning all the lights out in your garage and see if your headers are glowing (assuming you're running headers).
My point is that ANY inlet leak can cause the problem you describe but so can a host of other things. To me (granted I'm attempting to diagnose over the interwebz vs. looking at it) you description is making think that the throttle blade is being held just shy of completely closing. Air may be by-passing the IAC causing your idle to hang. It would also cause you to run lean at idle (i.e. glowing headers at idle with the lights out).
Try turning the throttle stop "in" a quarter turn at a time and driving for a bit to allow the EEC to readjust. It can be difficult to set the idle with the IAC disconnect method even if you ARE clearing EEC each time. That said... the EEC 'should' pick up minor changes after a time and come into it's own on settling for an idle (even with a slight inlet leak). Not so much if the throttle blade is no fully closing though. The TPS is helping to lie to the EEC about the position of the TB.
Worth a shot.
Good Luck! :nice:
