X cal oe x cal2, who has it?
ADRENLN
2,342
NJ
is this a good peice? is it a pain to use? im not a computer guy, i dont know what im doing most of the time with computers. so i fear trying to use this. i wanted to just get a custo mchip, but tim from mph said i will need this so he could make minor adjustments if needed.
i have to do a tune after i get heads and cams and gears. i want a dyno tune, but just wanted somthing simple till i get there.
my worry is reflashing the computer, i figure once i do this, it will be very hard to find someone to work on my gt if there is a problem. what experiances have you guys had?
i would love to do that, i just dont think i will be able to drive the car with heads and cams installed without a tune. id have to drive it to the dyno shop. the place installing it and the plane dyno tuning will be different.
I have the xcal2 and love it. You don't need a computer to use it. The tunes come loaded on the handheld. Your stock tune will be stored on the handheld too.
The only time you need to use a computer is to change settings.
If your dyno tuner is an sct dealer than get an xcal2. I love my xcal1, it works fine but the 2 is better (has data logging, end user adjustability). You can use tims tune on the xcal until you get to a dyno to perfect the tune. Then you will never need a chip again. You can have a different program loaded into the xcal anytime you change your setup.
It really only helps increase HP because it basically increases timing. You will get better throttle response. Now I only gained 7 HP w/ the SCT X-cal 2 dynotune. But the throttle response and the car feels so much quicker. You amount of mods don't matter. Will only help
christiesledd said:
yup, xcal2 is great! my tuner said the xcal2 is much better than xcal1
I take it that you took the car and had it dyno tuned with the x-cal2. Just curious about the cost. I'm debating on buying the tuner at right or going to a dealer and let them dyno tune it and buying the X-cal from them. I've used this place to get a baseline. Pearl02.
yup, i went to dyno speed racing in memphis, tn and ran on their dyno, bought the xcal 2 from them, and they tuned my car with it for me. great guys down there, it was a 3 1/2 hour trip for me and worth it!
