  • SN95 4.6L Mustang Tech
xcal ?
  • Thread starter Thread starter ANGRMNGT
  • Start date Start date Nov 10, 2006
A
ANGRMNGT
75
NC
Nov 10, 2006
  • Nov 10, 2006
Seems like an easy question, but can you retard the timing with an xcal2 (nitrous applications). Also can you remove the top speed limits.
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Nov 10, 2006
  • Nov 10, 2006
you can remove the stop speed limit, but i dont think you can retard the timing (yourself) unless you ask your tuner to add it into the initial tune.
cooper58d2002
98
Hope Mills NC
Nov 11, 2006
  • Nov 11, 2006
I don't know if I'm oversteping my bounds but I thought that the GT's don't have a speed limiter I have at least yet to find mine if it does.
Don 95Vert
1,091
Delaware, OH
Nov 11, 2006
  • Nov 11, 2006
Yes, you can retard the timing on it yourself but probably not enough. So you should get a nitrous file for it and in addition the fueling may not be best for nitrous if it was set up NA.
Don
A
ANGRMNGT
75
NC
Nov 11, 2006
  • Nov 11, 2006
TBH I'm not sure if my 03 has one but i have a friend with a 98 and he told me his cuts around 135. Only time ive been in that range is under spray and for fear of going lean ive always cut off about 125. Well going lean and the stock suspension and brakes scare me at that speed.
Stang|ess
Oct 18, 2003
941
Hawaii
Nov 11, 2006
  • Nov 11, 2006
IIRC, only the 99 with the 16" wheels have speed limiters.
cooper58d2002
98
Hope Mills NC
Nov 11, 2006
  • Nov 11, 2006
Correct if I'm wrong but I beleive the only reason they had speed limiters was the lack of Z-rated tires due to Federal mandations.
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
C
Fuse help please. 73 Mach 1
  • Curtis Harper
  • Oct 19, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 28, 2026
Curtis Harper
C
G
In expensive ceramic coating
  • gray owl
  • Jul 12, 2026
  • Mustang Sound & Shine All
Mustang Sound & Shine All Aug 18, 2026
NotaVegetarian
N
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
Brake Fluid shelf life?
  • Bullitt347
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2026
nickyb
