I finally had a chance to take the car out for a spin after testing the volts on the TPS. I wanted to make sure and drive it before tweaking anything else so I could get a new baseline. Believe it or not, the minor adjustments I made to the TPS seems to have worked. I drove the car yesterday for about an hour. It was pretty hot outside and normally my idle would have started to hang within 5 minutes of driving and continued to hang until I shut the car off.
Coming to a stop with clutch in the RMPs dropped down to ~1K like they did pre idle hang, then within 2-3 seconds down to ~800. I've always had the drop to 1K right away then it takes a minute to drop to normal idle. Don't know if all foxes do this, but I could never seem to get my idle to settle right away.
I did notice the idle seem to drop lower than normal on occasion after driving a while (600-700), but overall seemed to run pretty good. I may put some more miles on it then adjust the idle a little.
This has gotten me curious to see if adjusting my TPS to the higher side of the range will result in my idle hanging again. Outside of testing for codes, the only thing I touched was the TPS and both my initial test and slight adjustment were both within range.
