Z-T5 question
SRT
29
MA
Hey guys, new to this forum, I have an 88 gt conv with the zt5 and 355 gears, the question is that the zt5 has 7 tooth spedo gear, and my stock t5 had an 8 tooth spedo gear....does it make any difference when i go to buy the correct 20 tooth spedo cable gear???
Im about to put a t5z in my car. The place where i had it rebuilt said that my spedo gear would work but who knows.
The t5z was designed to be a direct bolt up HD trans. I don't know why ford would change something like the speedo gear.
I was just told that 89s and below have 7 teeth and 90-95 have 8 teeth.
7= 20 tooth cable gear with 355s
8= 23 tooth cable gear with 355s
T5Z =7 tooth
Snikt some 89 to 93 came with what Ford called a service trans with a 300 ftlbs capacity they also had a diffrent 2nd and 3rd gear ratio 1.99 2nd 1.33 3rd the tage number on your trans should be 199 or above I have three of these trans and they work good
199 is a factory 90-93 T-5.
You are right about the Service trans. It was actually installed in 85-89 Mustangs and had a 300 ft-lb rating and a unique 2nd and 3rd ratio.
The trans buck code on these transmissions is 1352-52-204
Since it's a "service trans" does that mean it was replaced under warranty or something?
According to mustanggt.org:
Tranny
Part Number 1st 2nd 3rd 4th 5th R Torque Capacity
lbs-ft
5-speed T5 (1989)8
E9ZR-7003-A 3.35 1.99 1.33 1.00 0.675 3.15 300
8 - This gearbox was introduced as a running 1989 upgrade. It has an 8-tooth speedo drive gear.
