sn95 brakes....
DEFWISH
87
Wichita, Ks
Okay, so Im about ready to start my conversion,We bought a wrecked 95 stang with no motor or trans. so I have the front brake assemblies (spindles, hubs, rotors, calipers,) I took everything off of that car as far as brakes go, including e brake and e brake cables. I am going rear disc and im gonna try the .75 in longer axles that were in the 7.5. i ordered the fox - sn95 passenger brake line adapter and Rear brake line adapters. i have a master cyl off of a 95 as well. SO what else do i need to do. :shrug: 3 -2 port conversion still?? and should i gut my stock pv and go with an adjustable prop valve. Any tips will be greatly appreciated.
ones like these, and how do you roll your fenders?
im pretty sure they are 9 in wide rims. ill double check tomorrow. not sure on tire size, but nothing lik 275. i plan on 99 + dual pistons when i get some more $$ but these should get me by right?
EDIT:: sorry to doubt you.. i think they are 8 inch... i still wanna measure mine tomorrow :)
i must be crazy
Since you've got the 17" wheels, do yourself a favor and get the 13" Cobra setup for the fronts. You can't go wrong with 13" of brembo twin piston goodness.
send me a cashier's check for em and i'll gladdly buy em... :D
I plan on going with a cobra upgrade kit or something... but i still need to buy a bizzillion of other things for other things in the car.
P.S. i bought the Front fox3-SN95 adapter, passenger side and the Rear brake line adapters, Pair from http://sn95brakes.com/store.php
I went with braided lines that had a flat head and everything fit up fine w/o those adapters :shrug: Just one less possible leak down the road, ya know? :shrug:
So where did you get the lines im pieceing my 5 lug stuff as well and i have the following:
94 spindles/hub
moser fox length axles
5 lug drums
99 gt calipers/rotors
not to sure what else i need and i haven't heard of this adapter they are speaking of
any info on this would be great and a list of other stuff would be good
