Fedex has been kind
-24"x12"x3" core bar/plate intercooler
-3" ID, 2mm thick aluminum tubing with rolled ends
*2 x 90' pipe
*2 x 75' pipe
*2 x 45' pipe
*2 x straight pipe
-3" silicone couplers
*2 x hump hose
*3"-2.75" reducer
*6 x couplers
*2 x 90' couplers
-3" polished aluminum BOV pipe (Type-RS flange)
-17 x 3" T-bolt clamps
-Vortech Mini-Race BPV, satin body, blue top (not pictured)
I'm gonna run probably right around the same power level, but with more timing and more fuel. Should also help the car from falling flat on its face in top of 3rd and 4th gear at the strip from too-hot IAT's making the tune retard timing. Total cost for EVERYTHING was only $468!
Best part of this is that I just put in a leave of absence from work till the end of the college semester...so I got PLENTY of time to put this thing together
*2 x 90' pipe
*2 x 75' pipe
*2 x 45' pipe
*2 x straight pipe
*2 x hump hose
*3"-2.75" reducer
*6 x couplers
*2 x 90' couplers
Nice 360 too.
I do plan an MMR aluminum block 4.6l, bigger fuel system, and MPH head/custom ground cams if I am to keep the car. I'm looking to rev the motor out as high as possible (low compression, custom cam, big heads, oversized valves, and really stiff valve springs, hah). I have an aluminum kit for my MIG welder, so I might weld the pipes if need be...but I've TIG welded a little bit, which I could do at my buddies shop if I had to.
. Do you know how many *s your running right now?
. Thats why I was for boost vs timing.
Hehe, seriously though, I've had the blower on the car since 10k miles or so, so its pretty damn fresh
