T-5 transmission swap on jackstands. is it possible?
Do you not have to drop the crankshaft any to change the rear main seal on a SBF?
no,you might be thinking about the oil pan it needs to be dropped....
Isn't there two different types of seals you can put in it? One is easy and doesn't seal as well, then the other is tough, but seals better? :shrug: Maybe I'm wrong. Dunno. Never done it before. I chose to let it go until the engine swap. The car made it. :D
Yea what everyone else said. The carpet trick works great. Also, when putting the tranny back up, be careful and take your time. I've spent a painful half hour (by myself) holding up the tranny lining it up to get it back in to the disk once. However the other time it went up and in on the first shot. It helps to try and roughly line up the splines on the input shaft w/ the clutch disk before you lift the tranny and try to put it back on. And/or if you have a buddy, put the tranny in a gear before you take the shifter off and when you put it back up try have someone spin the tailshaft with their fingers or slide the driveshaft back on and spin slowly that way and it should pop in quick minimizing your lifting time. THis is almost always the worst part of the job so take your time and do it right.
more good info
when i do the T5 swap, will i need a Transmission Input Shaft Seal too?
if so, will this one work?>
http://store.summitracing.com/partd...rt=RMG-8225750&N=700+-204213+115&autoview=sku
don't buy this seal from mail order get one at your local parts store you will save approx. $15....click on links below.these are good seals just ensure you install them properly...
http://www.oreillyauto.com/EW3/Prod...=74.167.93.28&keyword=seal&descriptionId=2005
http://autozone.com/servlet/UiBroke...ameters=|~With+manual+transmission&PageSync=5
thanks. i appreciate the tip. more money saved, the better.
so i DO need the transmission input seal?
also need the output shaft seal? having problems with this one. autozone didnt seem to have it
hey, sorry about the delay. Something came up and I ended up having to go out of town. I have a day off on wednesday so I'm going to try and install the RMS, clutch, flywheel, etc then. I'll be sure to let you know how easy/hard it is to get a teflon one on.
thats cool man. let me know :nice:
PROJECT T-5 / T-5 SWAP BEGINS TONIGHT
tonight will be the start of getting the car up in the air and removing the old t5/bell/flyweel/clutch/rear main.
hopefully will be done with it late friday night.
wish us luck :SNSign:
