MAF sensor question
I converted my 67 stang with a 289 to EFI a while back and got all the parts from a 1990 donor car. Now I want to upgrade to 24# fuel injectors, larger throttle body, gt40 intake, hotter cam. My question is can I use a MAF sensor from a 96 mustang that is calibrated for 24# injectors. I know I would have to change the plug on my EFI harness to mathch the 96 stang MAF sensor because it is a different plug but will the 96 sensor work with my 90 computer?
The stock 19 LB injectors are good to 280-300 flywheel HP. Unless you plan on exceeding that figure, your 19 LB injectors will be fine.
Swapping the MAF sensor will not get the job done. The MAF housing assembiles and sensors are designed to work together and cannot be swapped. Putting MAF sensor B into MAF housing A is not the right thing to do. With a very few exceptions, you can only replace a MAF sensor with a sensor with the same part number.
Ford's computers were designed to use the computer's internal programming to change the injector sizes. The Ford design never intended using the MAF or MAF sensors to alter the computer to use different size injectors.
The aftermaket MAFs lie to the computer in an attempt to fool it into working with different size injectors. Sometimes it works good and sometimes it needs some tuning. That's what people invest in add on tuners like the Tweecer.
To use 24 LB injectors, you will need a new MAF assembly from Mass Air Systems ( http://www.massairsystems.com/ ) or C&L ( http://www.cnlperformance.com/index.shtml ). The C&L uses your existing sensor and a new MAF housing and a sample tube to calibrate the sensor to match the injectors. Mass Air Systems sells a new MAF housing and MAF sensor matched to the injector size.
Mass Air Systems products are more expensve but seem have fewer problems than the C&L products.
JR pretty much answered the question already, but I just want to elaborate and emphasize a couple of points.
The factory Ford MAF from a 96 Mustang is NOT calibrated to an injector size. ALL Ford MAF meters are cal'd to the computer, and the computer contains seperate settings for the injector size.
If you are looking at an AFTERMARKET MAF from a 96 Mustang, then the calibration just won't be right. This is because the fox computer and the sn95 (post 95) computer used different MAF settings (software programmable).
With your planned mods you should be ok with the stock 19's.
In this case you can upgrade your MAF by using the factory Ford MAF from a 94-95 Mustang.
JRichker is a great source for doing this, as he has done it in his ride.
It isn't that tough, and will provide some hp without losing idle & drivability.
jason
