Which transmission?
98BLKGT
322
Chicago area
Should I go with:
Rebuilt T-5's 79-93 3.35 Super Alloy gearset, carbon fiber blockers, steel bearing retainer $999
or
* Heavy-duty "World Class" T-5 5-speed manual transmission with short-throw shifter.
* 330 ft./lbs. torque capacity.
* Double-moly 2nd speed, 3rd speed and countershaft cluster gears.
* Carbon-fiber 3-4 blocker rings.
* Improved synchronizers and bearings.
* 1-1/16 in. diameter 10-tooth input spline.
* 28-tooth output spline.
* 7-tooth speedometer drive gear.
* Cobra-style pocket bearing.
* Steel input bearing retainer. $1295
OR
Rebuild for $425+225parts(summit)=$650
Gears would stay stock
I take it both of these are just ready to drop in and go? The car has 300-350HP.
93 Notch with stock t-5 right now with a bad 2nd synchro. On a budget.
Both of these are HERE
my choice would be neither of the above...tremec tko500 would be my choice...costs a little more but well worth it...i have no tranny worries and i can upgrade without worring about mt tranny holding up...my 2 cents..
I would say the same thing, get a tko- you wouldnt have to realy worry about breakage issues. or you can get a T-56 instead /w with a D&D t-56 swap kit. thats just my 2 cents. :D
If i had to choose between what you have listed I would go with option #2 the world class t-5. I would think that a TKO-500 or TKO-600 would be a better choice. I have done the t-5 thing and i'm on tranny 6 now. With what I have spent on old junker's I could have done the job right the first time.
Yeah but you're in to mid 11s right? I should also mention couple other things that the trans. life depends on.
-I won't run slicks.
-Only a 3.27 gear for a while
-Nothing more then a stage one or two clutch
-No quicker then mid 12's
If you are going to stick with the T5, just keep it cheap. Get the most basic rebuild you can get away with because chances are its gonna break down the line. Second gear syncro could be the case but for me I banged up the 1st to 2nd slider gear pretty bad where the dog teath were flatened out on the tip. That was 80 bucks right there for the slider and 2nd gear. Also check for cracked shift forks too... found a crack in my 3-4th shift fork. Tear it apart and then see what you need to replace would be my suggestion before buying a kit which might not fix the issue. I swear my MGW was the death of my T5... the first time.
Kevin
Kevin
Option number 1 or 3 if you're dead set on staying with a T5. You already have a WC T5 in your car now, option number 1 is also a world class, and so is number 2. Your cheapest bet is just picking up the video from Hanlon, grabbing a basic cheapo rebuild kit from either Hanlon or D&D, and going to town on it.
:stupid:
Plus you'll get the added benefit of knowing how to replace 3rd gear and the countershaft if you ever decide to up the power. :nice:
With a budget, I would go with number one or number three. The T-5 will handle a little more than stock. 350HP shouldn't hurt.
The number one thing that kills transmissions is abuse. Missing shifts, powershifting, dumping the clutch at high RPM's...all of these things will bring a T-5 to an early retirement.
I had a 95 GT with H/C/I P-600B PRocharger and 3-core intercooler. CFDX clutch and a STOCK T-5....I went down the track 50-60 times and drove this car to work daily, with a lot of street racing. This trans was great, but I didn't abuse it. I had two other Mustangs with T-5's and they were great.
However, if you had more money to spend and plan on doing serious power adders in the future, go with something suggested above.
Although abuse certainly will contribute to the demise of the t-5….it seems to be the design of the tranny itself that is it's weakness. You can baby the tranny throughout it's whole life and still shear the teeth off of 3rd gear with simply to much torque (as was the case with mine). There seem to be guys out there that grenade their t-5 with 350lbs/ft of torque while others beat the piss out theirs with 600lbs/ft and claim they are indestructible. In the end….as SVT32VDOHC stated, if your planning on upping the power in the near future you'd be better off selling the t-5 and picking up something more capable.
Someone said that I already have a WC T-5, but there are manny different types of them.
Common ask questions:
Q. What is a world class transmission ?
A. All t-5 1985-2001 are considered "world class" there are aprox. 40 different models of world class.
Q. What are the main differences of the world class transmission's ?
A. 1985-1989 are the weaker models of world class, in 1990 Borg Warner upgraded the 2nd & 3rd and cluster. The result was a tourque rating increase from 265 ft. lbs to 300 ft. lbs.
The one above is rated at 330 ft. lbs.
