Should I go with:
Rebuilt T-5's 79-93 3.35 Super Alloy gearset, carbon fiber blockers, steel bearing retainer $999
or
* Heavy-duty "World Class" T-5 5-speed manual transmission with short-throw shifter.
* 330 ft./lbs. torque capacity.
* Double-moly 2nd speed, 3rd speed and countershaft cluster gears.
* Carbon-fiber 3-4 blocker rings.
* Improved synchronizers and bearings.
* 1-1/16 in. diameter 10-tooth input spline.
* 28-tooth output spline.
* 7-tooth speedometer drive gear.
* Cobra-style pocket bearing.
* Steel input bearing retainer. $1295
OR
Rebuild for $425+225parts(summit)=$650
Gears would stay stock
I take it both of these are just ready to drop in and go? The car has 300-350HP.
93 Notch with stock t-5 right now with a bad 2nd synchro. On a budget.
Both of these are HERE
or
OR
