My car getting slower ?
lvmustanggt
721
Las Vegas
Before I had cams done I used to run 13.5 1/4 miles at 103 mph at only 265rwhp. Now I got 293rwhp with cams . After my cams , kyb adj shock and struts and bbk LCA
I am running 14 sec 1/4 with only 96mph wtf ? Why am I running slower then before ?
Does any one know which setup is good on kyb adj shock and struts.
I have tried 1-4 up front and 4 on back shocks. back shocks can be set up to 8.
I used to pull 1.8 60' with MT ET Street but after I did my shocks, struts, LCA and MM SFC I haven't got 1.8 60'. what is wrong here ? I am not happy at all
There could be many reasons for the ET being off. I look at a run as ET being about traction and MPH being about HP. The problem I have is the MPH not only did not stay the same but dropped by 7 MPH. You should be able to run 96 MPH or more with a stock engine and car. When did you last have the car on the dyno? Can you post some old and new time slips?
last dyno was 293rwhp and 303 torque with cams. Track the same , I know that after
I did my shocks and struts , lca and mm sfc my car runs slow. My stock shocks and struts and mt et I used to pulled 1.8 60' but now I haven't got 1.8 60' after that. Plus
after my cams done I hear whistle comming about of my engine bay. Don't know where it's comming form. Only thing I can think of is valve cover cause I see some oil around it.
same track with 265rwhp I ran 13.5 , 1.8 60' 103rph
now 293rwhp and 14.1- 14.3 with 2.0 60' 96mph.
I just went to the track wed 21 march , I did 14.2 and 14.5 1/4 mile.
1) How much time past from your dyno test until you took the car to the track?
2) Find you oil leak and fix it
3) Find the source for the noise and fix it
4) Diagnose where you are losing HP - leak down test - if you do not have one a compression test. Remember that your cams can cause this to read below a stock engine this is normal.
I just got dyno again like week ago. I went to track wed 21 march. My tuner guy told me I am leaning at 6000 rpm and suggest me to get fuel pump.
I just bought this , it will be here today.
http://cgi.ebay.com/ebaymotors/ws/e...RK:MEWN:IT&viewitem=&item=270099158315&rd=1,1
http://cgi.ebay.com/ebaymotors/ws/e...RK:MEWN:IT&viewitem=&item=250054578315&rd=1,1
Lets hope the pump fixes the problem. You may have burnt a valve from running the car after your tuner told you it is lean. You still may need to do that leak down test. :shrug:
How does the car feel? Like on the street with 292RWHP 1st and 2nd gear should be TOTALLY gone froma slow roll, and gaining traction at around 60MPH. (with street tires that is)
I mean there would be a HUGE difference in feel between a 230RWHP car (96MPH traps) and 293 (107ish MPH traps) .
Also what RPM are you shifting at now when you run it in the 1/4? Lets just hope whoever installed your cams, did a good job.
First gear I don't even feel my car moving, 2nd is better 3rd full good. I am going to install exhaust and fuel pump tomorrow. I order centerforce duel frition clutch today with some upr clutch stuff. cams were done by sliver state motorsport, I shift at 6000-6200 rpm. I still cannot find where is this whistle comming from. It started after the cams install.
So when I install fuel pump what I have to do and as you said I only need to put pump not the hole big big white canister
