OK, about ready to give up, I replaced the pads on the rear drums on my '86 GT because they were worn and were squeaking. I replaced the pads, the hardware and the wheel cylinder. The problem I am having now is the drivers side squeaks when I first apply the brakes, but when you press the pedal further down the squeak stops. But I can feel both rears grabbing and the drums gets real hot, plus you can smell the pads burning, and the pedal feels a bit mushy when they get hot. I have everything installed correctly and adjusted, like I mentioned above everything has been replaced in the back and the drums look good. Can this be caused by a bad distribution valve, master cylinder or hoses? That is the only thing other then the brake lines that have not been replaced. What would make the rears grab, what am I missing?
Thank you,
Thank you,
