i have a set of 2003 cobra front brakes. Everything including spindles, calipers, rotors/hubs etc... i solved the brake line issues but should the spindles bolt up fine? will i have to adjust tow at all?
Your front track will be about an 1/8" wider than if you were using 94-95 spindles, but that shouldn't be an issue unless you are planning on running really wide tires up front.
