id rather not go with LT's should i go street heat instead???
Adam
I know I sound like a broken record ... Sorry ... CD with a scratch that repeats
over and over ... but ... I've gathered up so many different combos that it
is very obvious to see the trends when you compare them.
At the sake of everybody having to hear it once more
LT's will give you a gain over shortys down low and at mid range
Longer length runner uppers give good low end
but
Fall off around 5K
Again ... We are generally speaking here
but
You can confidently call that a rule of thumb
also do you think a 65 mm throttle body will be enough or should i go 70??
I can't be certain as I have not seen any data about this subject that I
would call 100% valid
At this point in time
and
Until I see data that I consider to be valid .......
I have to believe the whole tb size thing needs to be considered from
two different view points.
1) WOT
2 All other driving conditions except WOT
For #1 I can see bigger could make more power
For #2 I suspect in the effort to ensure #1 is the most effective ......
One could go too far beyond a certain point and it could cause issues
some have reported such as touchy throttle, and the like.
i really just want to make sure my car is not all top end and doesent have the power down low...
I understand and agree
Pulleys can help
Spark table optimization can help
A custom cam would really go far to give you what you seek :Word:
cause
You could specify your concerns for a focus on low end torque
but
If you don't wanna heed info like has been presented here
Well ... Please Believe Me Adam ... I'm not trying to be a xxxx head here
but
Would you take the info to heart of your cam guy
cause
He can cut you a cam based upon your desires
but
You gotta work it with parts that compliment it
and
I can assure you ... he is gonna tell you about which parts to use
You see how that all kinda goes hand in hand my friend
Just trying to show
Its all about a plan
And you gotta consider all possibilities
then
Do the research to confirm the possibilities
then
Research to confirm .......
how much of a hit you are gonna take with each compromise you make
Grady
