Street Heat VS. Track Heat HELP! ASAP!
Well Keith
I was not aware of the 308's anywhere in this thread
but
If you say so ... I certainly am not trying to say it ain't so
But Never the Less .........
Lets just state the obvious ;)
Who in their right mind in gonna run some High Ports with a tall gear :crazy:
Heck Fire ... who would run A N Y h/c/i combo with a tall gear like that :shock:
I just gotta believe if he is running that ratio ...
its a temporary kinda thing
Grady
You may not like it until you get the better gears. That combo moves the powerband UP and the low end is gonna suffer. We are just preparing you. If you have a vert..I would recommend 3.90's. Yo ukeep your 1st gear for street AND get great power all around. ;)
I think you'll like the track heat....
like grn92lx and I said, get the right gears with a higher-revving combo....
and some fun can be had.
get longtubes to offset the shorter runners on the trackheat...and you should find a decent midway point with it.
IMO, that setup with 4.10s would give you a grin from ear to ear....or you could go 3.73s....whichever floats your boat.
nope, not IMO
get the trackheat....and run with it until you get gears. your low end may suffer a bit....but I really don't think it'd be too big of a deal.
the end of the summer isn't too too far away.....
I just like doing things once and doing them right vs. buying something and then swapping it, etc.
I've never seen/felt a combo like what you're talking about...with stock gears...so the best answer I can give is...maybe
There's a possibility that it'll be worse than stock
but once you get the gears, you'll be in your power band a lot sooner and the low end will be helped out.
I have a ported cobra intake...and it flows around the same as a street heat....which basically means it chokes around 5500 or so. I'm going with a trackheat so I can make better power beyond 5500.
This is what I see. You have some pretty good flowing heads and, IIRC, a decently hot cam going in....you don't wanna kick yourself down the road and have to change the intake (though it'd be easier for you to change in your case) because it poops out at 5500 or so rpm.
a good cam grind can net you some low end back....and also make it breathe well on the top end...
First of all, 3.08's suck on anything unless you have a kick azz blower or a viper engine in your car. 3.73's are not quite enough for a vert's weight and the 3.90's felt like they were just right. Yo uwill hate 4.10's unless you are a quartermile racer. The 3.90's were juustttt right. Revving any higher on the b-way would have sucked and you will blow off 1st gear.
"I have a ported cobra intake...and it flows around the same as a street heat....which basically means it chokes around 5500 or so. I'm going with a trackheat so I can make better power beyond 5500."
This is not correct. The street heat has good low end and overall better than stock and FALLS ON its FACE at 5000. I have owned both. ;) Yes, the car will still pull but yo uknow it is time to shift. 5500 is too far and going waay to nowhere land.
(edit) the gears question is always subjective to the person. I am not saying I am totally right.
thanks for letting me know that pokageek, I've never had any actual first hand experience so what I say could be considered moot, lol.
I also have a blown combo, and it's centrifugal too so that might be why my intake's cut-off is elevated somewhat. NA on my same setup my intake crapped out at like 5200 or so.
about the gears....I agree with you 100%
It's all up to how much you want to trade off.
No problem man. The street heat is different from any other I have had in that respect. Kinda weird. But it does a much better job than stock (remember that with the 4200 and no power, lol) I have heard of variations on the stock intake but still much like an old diesel ,lol.
yeah blown is nice. Kind of like being hit by a dump truck and pushes the rpms a bit.
haha, yeah...with my setup there's not so much of an on/off type of power feel. I've been in some car's where it feels like someone flipped a go fast switch at like 3500.
My stock intake was a gt40, so it was a bit better than the GT stocker...but I've been in a stock GT, and that thing gave up the ghost past 4300.....kinda sad
This is not good information. he will hate 4.10's but 3.90's are just right? Come on dude, the difference is neglegable. I have 4.30's in my pump gas STREET car. I don't hate them, I LOVE them.
Adam95, like I said earlier, track heat upper, 4.10's and a 75tb are the ticket. If this is too fast for you, use the street heat and 3.73's :)
Im with GRn92lx, Gear the car for the engines power band. 3.73s were perfect for my streetheet but once the Holley went on they were a bit dogish. About to drop in the 4.10s next week
the only reason I didn't go with 4.10s is because I'm supercharged with minor H/C/I
with 3.73s I don't have traction in first, I lose traction at 4500 in second....and at the top end of third the back end gets happy.
that was on falken fk451s which are a decent tire (also 285s)
If I was doing a NA combo, I would do the 4.10s, hands down.
The only thing I can say concerning gears is....drive someone's car that has 4.10s in it and drive one with 3.73s (having a similar combo)
