It is quite clear there is only one way to resolve the issue to hand between the rival parties.
Rock paper scissors. PM me your respective choice, I will review the submissions and declare the rightful victor. Please, no "nukes" I don't care if you used them in 3rd grade, the choices are rock paper and scissors, standard rule set, 3rd revision as dictated by the national RPS council. Rock > Scissors Paper > rock Scissors > paper.
Submissions will be expected by 6pm PST today. Failure to submit a proper answer will be an immediate forfeit.
If you are unable to send a proper response due to literacy issues or complications that may prohibit you from properly spelling "rock" or any of the other choices, a picture of a rock will suffice.
Good luck gentlemen, and may God be with you.
since you called "no nukes" does this mean that moab's and daisy cutters are out too?
As for your piston speed theory, why a motor stays together at high rpms, isn't all about piston speed, it's more a combination of the strengths and weaknesses of the combined parts and the centrifugal force that stresses them. I don't know what the stroke is of your Yamaha but I doubt you're accurate in guessing a comparison to a 351W. That was a poor choice anyway with it's too large main bearings for the rpms. Nascar and dedicated racers use the smaller 351C or 302 bearing size in aftermarket blocks to avoid this problem. Try again junior.
