I got some new pads for my Cobra calipers (fronts), and haven't looked at the caliper yet and forgot what the inside looks like.
Questions:
1. Was there one piston per side of caliper (F/R) or were there two on the front or the back?
I don't recall lol.
Cobra calipers are different than GT's IIRC, so I couldn't tell you this for sure. If what I'm thinking is right, the front caliper has 1 large piston that pushes the pad into the rotor and the other pad is set in place.
2. Where do you place the C-clamp, over each piston one at a time?
Just over the piston yeah 1 at a time. If yours has 2 pistons I'd assume doing them 1 at a time would be fine but you COULD play it safe and put a piece of wood over both so tightening the clamp compresses both
3. Do you put anything between the clamp and the piston (wood, etc)?
Nope
4. What "lube" do I gotta go buy?
Wal Mart Special should be fine, as long as it's labeled "BRAKE LUBE/GREASE" or something like that
5. The box came with a few loose metal clips, other than the ones already attached to the pads. What are those for?
Would it be possible to get a picture of them? Only metal clip I can think of is shown here http://img.photobucket.com/albums/v75/Dusstbuster/Picture_1722.jpg Otherwise they might be for the rear brakes. It's been so long I'm starting to forget things!
6. What size C-clamp do I need to buy?
The one we use allows it to clamp over about 5" I think...probably from my palm to the last joint on my middle finger
Thanks.
