It is the most annoying ride ever. this is my fourth fox and none of the others rode like this. i know it is the springs.
So, after the Holiday i am having the following installed: H&R progressive rate springs, Bilsteins all the way around, and an AJE K Member that uses the stock springs using their perch kit.
do you think it will ride better?
I am using the 225/50/16 tires.
Also, i need more traction in the rear. i already have steeda lower and FRPP upper contol arms. so, i was thinking of putting on a set of drag radials. Question? what size and will it effect handling much?
