After spending countless hours trying to find out where to best spend my budget right now, stock manifolds and exhaust will do for now simply because they "work"
However, while the motor is somewhat apart I have decided it would be a good time to think about my compression ratio.
Apparently gt40p heads are 60cc combustion chamber, and my old 66 289 heads were 54cc. I have a good oppritunity to take the heads off and have them milled.
Would this require the need for longer pushrods? I am using non-adjustable roller rockers right now, I suppose I could just get shim kits, but are they really necessary? I think I ended up using pushrods from some ford truck with the roller engine to have the valve geometry correct, and I was under the impression that with hydralic lifters it doesn't need to be "perfect" in a sense.
That being said, while I am getting them milled I an open for suggestions. Should I go ahead and get them milled down even more for higher compression? Valve clearance issues? Intake manifold issues?
Anyone want to buy a set of gt40p heads?
For reference, the cam in the car is an edelbrock performer RPM. It says it likes high compression (it told me when I went to install it), so maybe the low compression really is hurting the power.
