after removing the elbow, i had to do something about my old cold air induction. so i decided to try making a custom home made one and see how much cheaper it would be. i also wanted to put the mass air in the fenderwell too. so i went to lowes and bought some 2 feet of the thick 3 inch I.D. pvc, one 45degree elbow and one rubber connector bend. i also got a male brass hose connector and a rubber grommet while i was there. when i got home i put the rubber connector on the throttle body and mocked up the pvc to see how long it needed to be. cut the pvc put it on and then put the 45 elbow on the end. after about 30 min of cutting and reassembling i got it to fit. i put the filter and mass air in the fenderwell and mocked it up and positioned it so it would fit. i didnt have to make the hole into the fenderwell any bigger. then took the rubber grommet i bought. i took the act sensor in with me to find the right grommet for the sensor. took a 7/8s paddle drill bit and drilled the hole where i wanted it, put the grommet in, superglued it in actually and screwed the act sensor in. then drilled one more hole for the hose from the valve cover, tightened it up and put it all together. then after all was said and done, put 2 coats of primer and 2 coats of silver spray paint on the pvc. all in all i spent about 25 bucks.
here are some pics, comments are welcome
