Crappy ford tune
bhuff30
6,037
35
129
Olathe KS
I've got a 97GT, bone stock except for an off road H-pipe. After reading an article online from MM&FF, I was curious about the air fuel ratios on my 97. On their stock 96, the air fuel ratios were around 13.5:1 in the mid range, dropping to 12:1 at higher rpms.
I put the wideband on the 97, and it is not pretty! It is actaully around 13.8:1 in the mid range, dropping to 12:1 between about 4000 and 5500. That is scary lean in my opinion. :eek:
Why in the world would ford make it so lean in the low and mid range? Clearly, there is a lot or torque to be gained making the mid range richer and the top end a little leaner.
So what is the cheapest way to modify the fuel tables myself? (ie, which tuner).
I am very interested as well, I hope some modular guru's chime in. I think I can answer part of your thread. During 96....Emissions got really big hence the midpipe, so maybe thats why they put that tune on the car. I think 96-98 has the most restrictive crap on the car.
looks fine to me. supercharged cars typically run 12.5:1 below 4000rpm and N/A cars typically run 1 point higher a/f ratio than blown.
Most of you say it looks fine, but MM&FF picked up 12ft*lbs by making the mid-range richer. I'd rather see 12.9-13.2ish on an NA engine.
A.) take anything in MM&FF with a grain of salt.
B.) Ford has to tune for emissions and gas mileage as well as power. so power will not be the max possible straight from the factory.
After I dyno'd my car with all the mods in my sig, my AF was around 13.8 leaning way out on the top end.
I added fuel and adjusted my spark advance, brought the AF down to around 13.4 or so and I gained 6.9 rwhp and 13 lb ft of tourqe.
I had been driving a while with an AF ratio like that, pretty scary.
