Polished the Stainless side-pipes ~pics~
CobraRed_96_GT
1,421
UCSD/La Jolla
If people would like i could make a how-to thread in tech about how to polish stainless - it isn't really the same process as polishing aluminum at all. I used wet sand grits and metal polish then poor boy's paste wax (to prevent rubber from sticking to pipe again) - but the proper way is emery and stainless compound on power tools, but this way works as well.
Having exit pipes by the tires and low to the ground make for a pretty abrasive environment.
Before:
While wet sanding, the tire side of the pipes were covered in old burnt rubber from the track and the like which was cemented onto the pipes. This was indeed hard to dislodge, it was like taking off cement from steel.
Ahh the simplicity of properly made side-pipes
My home made terrycloth/cotton buffer:p
Finished polishing after the last 3000 grit run through:
On the car, sorry for poor lighting:
just dust sitting on top of the pipe:
polished mine up 2 weeks ago.
get some soap and water, steel wool, and 1500 grit sandpaper, simple green, and bug and tar remover.
get some boiling hot water, put it in a bucket dip the tips in there, and let them soak for a few minutes get the stuff on there nice and warmed up. take your bug and tar remover and wet your 1500 grit and starting lightly sanding in one direction only. then take your simple green and spray them good, let em sit for about 5 minutes. now with the simple green still on the tips, take your steel wool and rub back and forth in the same direction as you did with the sandpaper. once that's done, rinse the tips off, and dry them really good. now take some blue magic metal polish (works on chrome, steel, aluminum) and apply generous coats to both tips...let it set for about 5 - 10 minutes. now take a damp (i stress damp, not wet) cloth and start buffing manually, and use some elbow grease. once you have the desired result, wipe 'em dry and you're done. now go reinstall them and show 'em off.
