Deep Dish bullitts on a 65...how??
Just order a set of Bulllitts with wicked backspacing. Thats all you really have to do. I don't think you would need to narrow the rear end or anything. The reason they're so deep is because they're probably wide tires and the person didn't want to use a spacer or wheel adapter.
I have 17" X 8" rims on the back of my 65 with 4½" backspacing. They have a deep lip. I did have to trim the rear fender lip though.
Deltascrew,
Just out of curiousity, was it your rim width and backspacing that required you to trim the fender lip or was it your tire size? What size tires are you running on the rear?
The car in that ebay add looked like it was running a pretty narrow tire compared to the width of the wheel. Look at how "ballooned" out the side wall looks.
Deltascrew,
I am running 245/45/17 only the tire rubs, not the rim. a 4.75 B/S rim would fit better , but Coy's only offers a 4½ b/s. even after trimming the fender lip mine still occasionally rubs, so I added air-shocks to keep it from bottoming out.
if you went with 225/45/17 you would probably not have a problem
if you want wheels with a larger dish you're going to need a smaller rear axle. I am ordering a custom axle from tcp with the new rear suspension and I have the choice of how wide I want the axle to be, i'm basing my decision on what kind of dish in the rear wheels I want to get. I'm still unsure of what I like so its still up in the air
Deltascrew - can you post some pics of the rear wheels fitment?
these pics aren't that great, but here you go
these are Coys C-5 Chrome 17" X 8" 4½" B/S
with Nexen 245/45/17 tires.
<a href="http://picasaweb.google.com/mustangbrantley/1965Fastback/photo#5197810301072474306"><img src="http://lh6.ggpht.com/mustangbrantley/SCJU7f1KgMI/AAAAAAAABRI/TCP_yOVrvYw/s800/IMG_4491.JPG" /></a>
<a href="http://picasaweb.google.com/mustangbrantley/1965Fastback/photo#5197810399856722130"><img src="http://lh5.ggpht.com/mustangbrantley/SCJVBP1KgNI/AAAAAAAABRU/pOBMv5WJ_e0/s800/IMG_4493.JPG" /></a>
Extremely hard since the stock wheel wells only have 11 or so inches in width
So that would leave .25" space on each side of the wheel...no problem. I guess a mini-tub would be in order.
I have heard that even with a mini-tub, the the inside panels and rear seat will not fit anymore. Has anyone done this a so are there any and if so are there any pics of the process?
Your math has forgotten to take into account the section width of the tire mounted on the rim which is 12.5-13 inches. Which means your frame rails would need to move a MIN of something like 2.5-3 inches to get it all under the sheetmetal of the car....which is a little more involved than a mini tub.
So you are saying that it would be more of a back-half car then...
I'll need to figure out something to get more rubber on the road.
So I went down to Specialty to see the car yesterday and the rear's are actually 18's and the front are 17's. The rear tires are really streched on the wheels (as you can see by the pictures). The rear tires were 255/35/18 (fronts were 235/40/17) and I could see where the guy cut notches in 2 places on each leaf spring in order for the tires to fit. Also looked like he made some extra room in the wheel well.
how much power are you planning?
I have a 410 stroker and at the track the 275 drag radials provide plenty of traction with no spin.
I have a 347 with a vortech and methanol injection which is over 600 to the rear wheels. My 95 Cobra had less power with 315 drag radials and more suspension work and still wouldn't hook up until 3rd gear, depending road conditions. The 65 is lighter with less rubber on the ground. I guess I could run some 15" wheels with stickier compound tires.
