Dropping a 4.6l aluminator N/A long block in sotck 03 Mustang GT
just trying to create a parts list... Please help me listing ALL additional parts i will need. Thanks
:flag:
Block Specs (FRPP)
# 4.6L (281 cubic inches)
# 10:1 compression ratio (nominal)
# Forged pistons
# H-beam connecting rods
# Forged steel crankshaft
# Aluminum block M-6010-A46SC
# Blue cam covers M-6582-A54
# Assembled long block with 2003-04 Mustang Cobra cylinder heads and camshafts
# Includes 99/01 Mustang Cobra timing chain cover, water pump, Cobra windage tray and oil pan
I wouldnt buy that unless you are planning on putting a bunch of spray on it. It would be a bulletproof n/a combo but to me paying all that money for forged internals and not putting a bunch of boost (with the n/a the comp. is too high) or nitrous on it is a waste of money. You could put 4v heads on your stock block or get a junkyard 4v motor for a lot less and have aroung the same power n/a. I would get the supercharger aluminator (with pi heads it would be close to 9.0 to 1 comp) and pray for a blower someday. Or send it to me and ill tell you how it works:D
money is not an issue. and i am planning on getting a blower sometime after the swap... just getting the N/A version because wont have blower for a while.
-now, back to the reason for the post....
PLEASE HELP WITH ALL PARTS I WILL NEED.
-4v intake, upper/lower
-4v exhaust manifold (prolly FRPP shorty headers)
thanks for the help.
From what I am reading you are basically buying an aluminum block with STOCK 03-04 heads/cams, and beefed up internals. Problem is, the compression isnt even 1 point higher than what your car came with stock. Work on the piston selection to raise compression, or just opt to buy a supercharger. IMO< you are going to be spending thousands on that engine and having minimal gains
