Stan Weiss
Without knowing at what altitude he is racing at it is hard to say how HP is losing because of the altitude.
We need to look at your dyno sheet, the shape of the curve at peak HP power will dictate how many RPM after that point you need to shift.
. More than likely he was dyno'd and tuned in the same area he is racing in which means if the dyno sheets are ever found the numbers should be comparable to the traps he is running. But if he dyno'd say in Houston but races in Vegas then yes, there would be some questioning going on. Simple misunderstanding it seems.
