After reading through a number of old T-5 swap posts I have made a few decisions and have a few questions.
I'm planning on using a late model bellhousing and clutch lever.
I was planning on converting the linkage to hydrolic but was recently told that my power brake booster convertion might get in the way. Is this typically a problem and is the same problem encountered using a cable conversion kit? I also am running long tube headers incase that effects my options.
I also read that the speedo cable should be changed from a manual to auto since I'm changing from a toploader. Is that right?
I've read that approx. 1" should be cut from the driveshaft but also read in a thread that a conversion slip yoke is 1" shorter and would not require the driveshaft to be cut. Is this true?
On another thread I read that a throw out lever fulcrum adapter kit is required due to a 3/4" difference.
So far I have the trans, late model bellhousing, clutch and pressure plate, and clutch lever and am trying to figure out all the other pieces I will need for the conversion. This is what I'm thinking I need:
swap crossmember
cable or hyd clutch linkage
auto speedo cable
slip yoke
throw out fulcrum adapter kit
block plate and clutch lever cover
drive shaft shortened?
Any clarity you could shed on these questions would be greatly appreciated.
swap crossmember
auto speedo cable
slip yoke
