saleen hid, ford oem hid or kit converstion which is the best route to go?
mandoq
los angeles, ca
Hi, im looking at getting some hid headlights but dont know what to get. Do you guys thing i should get the saleen or ford oem hid which are like $900 or get xenon kit converstion for like $250. Its the xenon kit a true hid and will it look bright like the whole saleen hid headlights.
I heard that too. OEM Ford HIDs require their own wiring harness to be spliced into the existing 05-07 harness and that can get messy.
Any aftermarket kit will come with adapters for easy plug and play operation so the choice is between Saleen and Conversion. The Saleens will give you the most legal setup by having the correct reflectors and lens housings that are DOT legal. The conversion won't have that but will be significantly cheaper.
The wiring shouldn't be messy. The harness is a mirror of our harness. The ballast just needs +12VDC from the low beam. The high beam +12V is used for the solenoid.
The problem is that the OEM assembly costs $1000 from Steeda. If you have money to burn, go for the OEM assembly.
