5-speed pedal swap
94GTMOOSE
303
jersey shore
i am swapping my pedal assy. for my aod to 5-speed swap. i noticed on my aod pedal assy there is what looks to me like a vacum operated switch. And on the 5-speed pedal assy there is just a switch.
my question is, what do i do with the vacum hose?
94-95s have the vac switch and the 96-98 pedals do not. Any chance your pedals are not from a 94-95 GT/Cobra?
FWIW, if things get tight, dropping the steering shaft completely out of the interior helps a LOT. The write-ups I saw didnt mentioned completely getting it out of the footwell, and since it only takes a minute to disconnect it at the rack, it's worth it to make the pedal box go in faster.
Good luck.
You mean the one in this picture?
That switch is for the cruise control. Just transfer the switch and any other needed parts over to the 5-speed assy. There should be a spot to mount the switch the same way it is on the AODE pedal assy.
i have taken some pictures myself. i want to know if i have the right pedals. there is no spot to put the vac switch on my 5 speed pedal. is there a way to make this work
ok this sucks. i went and looked at a picture 94-95 pedals and turns out that i have a set for a new mustang. This really blows because i have to drop the car off in a few days and i need to have all the parts.
Is there anyway to make this switch work or am i screwed.
your the man. all is well now.
i hope you didn't dive under the car to take that picture on my account. if you did that was cool of ya. i owe ya one
Easy enough top take photos, just stick a digital camera under the dash - no need to crawl under there. :nice: Sorry to hear about the wrong pedal assembly, I don't know if you can swap things around and make it work. The best bet is to put off the swap and get the right pedal set. :shrug:
