Wheel offset & backspacing...
EPIK
796
LEFT COAST
I am interested in a set of wheels I found, & would like to run em on my fox. It says they are for 94-04 stangs, but Im not too sure how they will fit on a fox. It says what the offset is, but not the backspacing... Here are the specs
Front wheel 17 x 9" - 24mm
Rear wheel 17 x 10" - 20mm
I notice that most of the rear deep dish replica wheels have a +22mm offset for 10" wheels & +28mm offset for 10.5" wheels....These say that they have a 20mm offset??? Im kind of a noob when it comes to offsets, so will these stick out on a fox, or will they have clearance issues on the backside of the wheel???
Any info will help...Thanks:flag:
Epik,
This detail should give you clairvoyance. offset as in your case a positive (+) 20mm offset is simply the dimension past (rim width)/2 or backspacing - ( rim width/2 ). Make sense ?? most I have seen say 22mm offset, yours say 20mm . . . a difference of 2mm is virtually nothing, to put things into perspective, an inch is 25.4 mm so we are talking less than 1/16 in difference.
In any case, it would seem to me that these wheels should fit your fox beautifully. Of course this depends on what type of rear end you are running . . . if stock, you'll be fine, if SN95 5-lug, you'll still be fine. You may have to remove your horizontal quad shocks, which is no loss really. But I would consider some heavy duty upper/lower control arms to pick up the slack. If the car is lowered any, say 1 1/2" . . . and you plan on running 275's or larger in the rear, then I would plan on rolling in inner rear fenders. 245's should word just fine up front on a '91 with little to no rubbing and look great on a 9" rim.
Thanks for clearing all that up 4 me bro.... Im thinking these wheels will fit perfect, that is if I win my Ebay bid.... I will run a 275/40/17 in the rear, & most likeley a 245/40/17 in front...My car is on sportlines, so it is pretty low, & I will be running bilsteins, & maximum motorsports LCA's so there will be no quads on the car....
thanks again 4 the help Cobra92usa:D
im also looking for DD bullitts.
im scared of how long the finish will last on ebay rims.
ill be using stock length 5 lug axles. dont know about you
Im gonna run stock length axles, most likely ranger axles. I think the finish should last quite a while because they sell the same knockoff wheels everyone carrys....
