My Parts List
DocG
5th graders > me. They're not bant
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Ok, hopefully you 5.0 saavy folks can help me figure out what all I got here on my new ride.
Here are the specs I have so far on the engine. I will hopefully be updating this thread with some pics of some parts that I'm not sure what they might be...stock or not, etc.
Here's the engine build.
Excessive motorsports shortblock. I have no specs on this shortblock. I wonder if somehow I can call them and get any info about the order...but its from like 2001.
The build was done locally by a reputable Mustang shop....Pauls Auto and Engineering in Cincy. Here are some of the specs from what I've seen in receipts.
306
Holley Sytemax2 kit
6.5 chromemoly pushrods
SHD timing chain
Cam#2 – 221/223 276/280 .509/.509 107Deg
24lb injectors
Holley Alum Heads – 1.94/1.60 valves
Cobra 1.7 Rockers
Votech MAF - assuming it matches the injectors
MAC ram air setup, mounted below front bumper.
TB - not sure, afraid it may still be stock? Will post picture maybe you can help me figure it out.
So far, does this stuff seem like a pretty good setup?
Suspension
Tubular K member – MU-2000TK2
MM LCA’s adjustable
MM Steering shaft
MM 1/4” spacers
MM standard torque arm
HR Race Springs
Last owner put on cheapo KYB shocks :(
Ford Racing front A-arms
MM panhard bar
Front/Rear strut tower braces - rear is Saleen, front is Steeda I think
Cobra sway bars front/rear
F/R disc brake setup - still 4 lug though
Welded in full length SBC's
From what I can tell the TB has no markings on it.
Does this look like a stocker? Does anyone know what type it might be? I can post other pics of it if that would at all help.
should run pretty decent. take the intake tube off and take a pic of the butterfly. or just measure it. my ford racing 65mm throttle body doesn't have any markings on it, i bet the 70mm doesn't either. it could be one of those.
Will do. It runs pretty darn good. Especially after it was throwing codes and I put a new TPS on. Runs great now! :D
Stupid question, but I wonder how much HP this thing makes. Its definetely setup for higher end power rather than low end.
