does the nitto drags tires are they any good. or go with a mickey thompson tire and will a size fit a 255 50 16 on a pony rim
i loved my nittos they will last longer than the M/t's. Depends what you really want out of them?
MTs will hook better, a lot better, but the Nitto makes a good all around tire!
Bingo!
Nitto's r good for 15,000 miles. M/T's maybe a 1/3 of that.
My buddy has them and says they're worthless until 3rd gear. He said they're barely better than his street tires.
Funny you mention this here was my "test":
Tire #1: Falken FK452 285/35/18 @ 35 psi.
Tire #2: Nitto NT555 275/40/17 @ 16 psi.
Both done at the same race a year apart, similar weather, similar prep etc... Car had NO power changes. Both races were the FIRST time I had ever driven on the respective tires.
Tire #1 was launched from an idle. Rolled into the throttle. Ever so slight spin into 2nd gear.
Best 60' was a 1.91, and went a couple mid 1.9xs.
Tire #2 was launched more aggressivly. Rolled into the throttle. Spun a fair amount in 2nd gear.
Best 60' was a 1.93, and went one other 1.9x.
Nitto only makes 1 size for a 16'. Yes, they fit on Pony's very nicely.![]()
You are an excellent driver though. Most of us wouldn't be able to do that. I pulled a 1.888 and a 1.9 on nittos those two times and that was it. The rest were 2.0-2.2 but then again the sun went down so it got cooler.
.Ehh with practice I think those numbers are reachable. Now had I say 1.71 60' on radials, then I can see it.
I'm disappointed I didn't hit a 1.8 on the Nittos, but I've had zero practice on them. Bolting on some 17" ET Streets tomorrow though.
I get what you're saying, but if it's his skill that gets him those numbers on street tires, then wouldn't his skill get even better numbers with a drag radial, if indeed that DR was a better hooking tire?
All others were low to high 2.2's. Car had stock suspension too, minus Mega Bite Jr's.
