Well after running a few tanks of gas and getting on it alot as the new found power is niceI have found 1.7 more MPG
This software kicks ass!
Thanks, I was just about to load the newest tune you sent. I hurt my back Friday so I havent screwed with it yetGlad you like it , let me know when you get ready to do the cobra
Correct.ground offset is for datalogging the wideband with the SCT software , the sct tuners have an input to datalog the air/fuel with the other parameters at the same time and you have to set the ground offset in order to get it to work correctly ....unfortunately the Sniper interfaces at this time dont have the air/fuel input yet .......so nothing you need to worry about .....
Thanks
Willie
Yes, I tune my own car with the PRP. It is easier for me to understand because that is what most performance shops tend to use for tuning and I know a lot of tuners.Cool! I didnt know you were a pro racer as well![]()
I still have the program, but I only have the computer code for my old GT. I decided to have James @ RWTD tune the cobra....and holy cow he did explain alot of what he was doing and it freegin blew me away. Alot of it even went over my head...and I am def no noob. He gets super deep into the tune and makes it truely right....but the only way to find these tuning techniques out is to join a forum where they all talk...its $100 a year or something I think.![]()
ANYWAYS congrats laser!!!!!!!!! Have fun with it....and like sleeper said, when is it going to be the cobras turn?????
Correct.
Could you explain how to datalog the A/F with your software then? I am a bit confused. I am just curious to know because I have not had any experience with Sniper, nor do I know anyone who has run it before. It seems like it could be a little more user friendly than the SCT stuff. (Although I already know how to use the SCT software)
You would be surprised what you can learn on ModFords if you spent some time reading. James seems to be familiar with the software but I have a close friend who had him mess up a tune for his car and his customer service SUCKS!
It seems like 2002BLGT seems to be very on top of his customer service.![]()
Gotcha!I just use 2 separate datalogs from my LM-1 , datalog air/fuel and RPM , and then datalog the Sniper Recon with your basic PIDs loaded , fuel trims , MAF volts , etc, and RPM , and then use both charts to compare RPM/ MAFvolts , and air/fuel ........they same way every SCT dealer did it before people figured out how to datalog the air/fuel with the SCT programmers
I just recently installed a vortech kit on the stang, would this software work well for me? I have nothing in it but the stock tune, and have yet to crank it. (Winter blows!) How in depth are the options to change things, like for a GT supercar pump and 42lb injectors? Would I need to see the tuner at least once?
Just get it from 2002BLGT. You can do a base tune with the software and send him the tune. He can edit it and tune your car remotleyI just recently installed a vortech kit on the stang, would this software work well for me? I have nothing in it but the stock tune, and have yet to crank it. (Winter blows!) How in depth are the options to change things, like for a GT supercar pump and 42lb injectors? Would I need to see the tuner at least once?
