gasket matching / gt40x heads
Dec 5, 2006
153
Well im wanting to know if there is any advantage to gasket matching, i have a cobra lower that has a smaller port going to my heads which has a slightly bigger port, would it be worth it to match em up?
1 more question , im looking into a set of gt40x heads for 650 assembled, would this be worth it to give em a try , im kinda on a bit of a budget right now and i think this would be a pretty good upgrade from the e7s i have on there right now , am i right. If i do go ahead im thinking of having a cam in there while the heads are getting installed, just not sure on what cam to run with the gt40x 303.
# Chamber Size: 64cc
# Intake Volume: 178cc
# Intake Valve Dia.: 1.94''
# Intake Flow: 240 cfm @ .550'' Lift
# Exhaust Volume: 62cc
# Exhaust Valve Dia.: 1.54''
# Exhaust Flow: 170 cfm @ .550'' lift
Gasket matching... minimal at best. Full pro port job..... Worth every penny.
Gt40x are ok esp for that price if everything is in good shape. I think they are an old kind of outdated head design but should work for a budget build.
Right on , how bout ppl running the Ecam , from what iv herd it give some nice torque down low , ill be shooting for the stars on this 1 come spring , just gotta get my mods together 1st and am hoping for aleast 300hp.
Well i got me some ford racing heads from a guy who knew nothing about them and had them on his car for a short while ,he said they were X303 but it is stamped X302 assembled with 1.7 rockers on these heads? , are they 1.7 , is there away i can check, iv never took apart a head .
f3zm-6049 is on the aluminum head and tryed to serch this # but came up with nothing . Wonder if ford changed they part # on em.
With this set up what would be an ideal cam to go with .
Any help would be fantastic .
here is what I found
M-6049-X302* Bare Head (64cc Chamber)
M-6049-X303* Complete Head (64cc Chamber)
M-6049-X304* Bare Head (58cc Chamber)
M-6049-X305* Complete Head (58cc Chamber)
THE FAST, EASY WAY TO BOLT-ON 65 HORSEPOWER! TRUE BOLT-ON PERFORMANCE
For use on 289/302/351 Windsor-style engines
Improved air flow over original GT-40 aluminum heads
Intake flows approximately 240 cfm at .550" lift (at 28" of H20)
Exhaust flows approximately 170 cfm at .500" lift (at 28" of H20)
Machined for 1.94" Intake and 1.54" exhaust valve diameters
Unlike some aftermarket heads our GT-40 heads use either GT-40 or aftermarket performance: intake manifolds, headers, and valve covers.
Intake port volume 178cc, exhaust port volume 62cc
High temperature exhaust valve seats. Thick deck for improved sealing, increased section thickness in critical areas for porting, and webbed rocker bosses for improved strength. Designed for bolt-on rocker arms, machined for tapered seat spark plug or gasketed. Compatible with Ford Racing intakes, headers, and valve train components. Can be machined for diagonal exhaust header flange mounting.
High quality original equipment style 356-T6 aluminum castings, machining and components
Each aluminum head weighs approximately 22 lbs. – approximately 25 lbs. lighter than each cast iron GT-40 head.
These GT-40 style heads use AGSF-32C spark plugs
Each GT-40X head is leak tested prior to assembly
Head assembly consists of bare head M-6049-X302/X304 and GT-40 valve train kit M-6090-X302 featuring stainless steel valves. The valve springs are compatible with all Ford Racing roller camshafts.
INSTALLATION NOTES:
Will not fit 1986 5.0L with flat-top pistons unless pistons are notched for valve relief
Must use head bolt kit M-6065-D289 to install cylinder heads on 289/302 blocks or head bolt and head gasket kit M-6051-A50 and intake gasket M-9439-A50/A51
Check rocker arm clearance to valve springs with production rocker arms
Check your intake manifold for port match, not all intakes are compatible due to the tall high-flow ports
Must use M-9439-A50 intake gasket
I'm running a very similar set-up to what you're looking at. Click the "my mod list" link in my signature for details. The dyno sheet below shows the difference between an unported Cobra manifold and a Tmoss-ported GT40 tubular intake on my car.
Thanks for that withors , thats quite a difference in the torque range form a port job. Im definetely going with an ecam but am unsure if ill have the dredded clearence . Im sure i will cause i see alot of others going with this combo but with 1.7rr , i guess its always good to check that anyways.
