stock hydraulic roller lifter question
dmc919
41
i pulled 2 lifters so that i could temparaily make them a solid lifter and check ptv clearance. i took off the wire retainer and pulled out the top piece of the lifter but the bottom plunger peice was stuck at the bottom, the spring wouldnt push it up. i had to hit it against a piece of wood several times very hard before it would push up. is this normal?
Yes, considering it has ZERO hydraulic pressure being pushed through it. Oil PSI is what causes the lifter to "pump" up.
