can i fit 325/50/15 bfg drag radials on 15x10 welds on fox?
um 295 or 325?? Ive seen 325's I believe but it looks like crap the way they stick out and I am sure it would rub. 275/60 on a 15x10 6.5 bs fits nicely though and should provide enough hook for anything your trying to do.
Yes, if you use a big enough hammer.
I just can't imagine how that is a good idea. Does the rear suspension have any travel at all? It just looks like a good excuse to shred an expensive tire.
To the OP, if you really want to fit 315+ size tires, you're starting to get into mini tub territory. 315s can be made to work, but only with the exactly perfect offset wheels, fender rolling, and a really BFH.
That coupe posted above I believe belongs to Brent Davis from turbomustangs, I pretty sure it has a homemade mini tub and the tires are M/T 325/50's. To do it right you have to mini tub it to run 325's.
so does anyone make a 295/50/15 drag radial? don't know why do they jump from 275 to 325??
BFG did, dunno if they still do... but it may have been a 295/60, which was like 29.9 inches. Thats a pretty tall tire and im pretty sure it wouldnt fit. 275/60 is about as much as your going to sqeeze out of a fox wheelwell with no mini tubs
