- Sep 26, 2007
- 486
- 0
- 16
Sorry I meant for the Engine Combo. I wouldnt know what to do with that much torque.
Turbo is a little out of my budget.
$10,000 + sold '91 Fox would go a heck of a long way towards a newer car.
I personally think its silly taking out a loan for parts that aren't a necessity. Just sayin![]()
91fox. A turbo is out of your budget. Especially a Hellion kit. Looking at a $3,995.95 base price for one. Plus forged components.
A regular T5 like I mentioned in my first post is rated at 330ft/lbs. You won't be pushing more then that out of N/A 302. Unless you are planning on running sticky tires the T5 is more then capable. TKO5/600 if you want to be safe and have a little extra money to throw at it.
Your bottom end is fine. Get the rods machined and shot-peened. Your block will need to be bored and honed. Might as well get new freeze plugs and cam bearings. Your crank may need to be turned, have a machinist check it. This of course assuming there are some miles on the engine.
You need:
Piston rings
Rod Bearings
Main Bearings
New gaskets
etc.
You need to factor all this into your estimate.
Yeah, I guess it depends on the T5 being discussed.
I do not like the TKO transmissions. They have a habit of being a little difficult to shift at higher RPM's. Just get an A5 or G-Force transmission. It cost the same, weighs less, less drivetrain loss, very similar overdrive options, and no conversion needed, except the stronger 26 spline set-up for the higher HP versions.
Again I ask! What are you trying to accomplish with your car? There is a whole load of suggestions being given here and none of it makes any sense yet because we don't know where you're going! You have 10 grand and want to spend it is about all we know. You may only need half or even less of that money to get where you're going.
Before i do jump into things i want to ensure i have all parts that are needed. So like said before by another stangnetter im not stuck with empty pockets and an incomplete car. I want to be over 400 hp reliably, reliable as in having the car running mechanically sound. Being able to go far distances confortably.
As of now the car runs horrible. It has absolutely no pull to it. It is tired and needs to be refreshed. But if im going to freshen things up i want to upgrade it with performance parts.
Instead of buying oem parts I wrather put performance parts to get power gains and benifit from the work. Im not worried about paint or any interior work because the body is mint with fresh paint. I want to get it running strong and pulling hard.
I would just go ahead and buy a crate motor, because with a hci kit and haveing a shop do work to the bottom end it will probably end up costing the same.
I would just buy a tko 600 and call it a day to support the crate engine.
But then I would also have to work on the cooling system and ignition
What im asking is, budgeting.. Best crate engine that will satisfy what im looking for. For the best price. And if the money i save is an obstantial amount I would even put a blower on it.
I would'nt mind having new ideas and new views to looking at things.
Someone might say, buy a new 302 and just invest in a blower or turbo kit. Then youll have enough cash for supporting mods like a tko 600. Fuel and Cooling mods. And still have enough money to support shipping and tuneing
I have put a lot of thought into this, trying to figure my best route for this project.
Origionally I did intend to get a new gt-40 302. And just work the fuel, ignition and cooling system. Supported with a strong trans. And if i ever did decide to go big i would just put a blower on it. and call it a day.
But im open to any suggestions.
