Front brake job.. What went wrong???
I changed the brake pads on my stang i thought all went well but when i took it out for a test drive the car begins to shake: it does like a stop and go kinda thing when i apply the brakes especially at highway speeds... Can anybody tell me what it is i did wrong and how to fix it PLEASE
Thanks everyone
I had the EXACT thing happen on a different brand car with disc brakes - the brake hoses and calipers were shot. The pistons would not retract, and I had horrible "shimmy" in the front.
On my Mustang, when I had a bum caliper, I didn't get "shimmy", but the front brake got VERY hot. The piston was not retracting and maintained constant pressure against the disk. Drive it long enough, and you'll be able to smell it and fry bacon.
Hope this helps.
Hope this helps.
Posted via Mobile Device not to jack this thread but i am having the same problem you just said happened to your brakes..mine is with the drivers side..how did you fix that roblem?
I removed the caliper, and was able to pop one piston out . The other piston was "frozen", so I just bought a new caliper (thanks to advice I got on this board). Problem solved.:SNSign:
Ok so i was driving home from work and i noticed that when i brake the car, other than the horrible shimmy, seems to pull to the left(passanger) side of the car, when i got home i checked the calipers and the one on the drivers side front is the one that seems not to be working, do i need a new one maybe???
BTW the pedal doesnt feel spongy anymore after driving it for a while, but at highway speeds or when driving anything over 35mph the car still shimmys ONLY when the brakes are applied
brake shudder
if the calipers are pulsating, you may not have bed in the pads correctly. it take a few miles for the pads to adapt to the rotor surface. If your rotors were warped before you changed your pads, the the rotors may need to be replaced, not turned. The pulsating in the rotors are from hard sports on the rotor surface. even if you turn the rotor, there still there. On the soft pedal, you need to rebleed the fronts and see if it firms the pedal. did you have a soft pedal before you changed the pads? try this out and it should help. If you have purchased a hard pad, it may take alot of miles before it is bed in. follow the manufacturers specs for bedding in pads.
goodluck
