Thanks for all the input, I decided to pull the trigger and order the 275's up front. If I find they're too big I'll change'em out, it's just money!!!
)I know you have one of the nicest, best maintained Mustangs around...but that isn't a perfect fit
the sidewalls shouldn't angle 'in' to the tread like that, and tread width and the wheel width should be closer to the same so the section width (the widest part) would be about 1" or so wider than the wheel...that doesn't mean the 255/40 doesn't work on a 9" wheel, they just aren't a perfect fit
(and a 255/40 will be about 3/4" shorter than stock, so the speedo will be off or you may have ABS problems if the rears are stock height....sorry spend way too many years selling tires)
It fits perfect IMO
just give it more camber in the front
I have 275's on 18x9 wheels, and they fit pretty flush with the fender. With my 18x10's (295) out back, they look fine together. The 275's however do rub on my swaybar in the front if I turn the wheel all the way in both directions.
exactly. Mine has about -1 degree camber, but I have another car, so I dont drive it unless its nice out. it used to be my DD up until about 3 months ago. It kills me seeing it sit in the garage. Just cant wait for it to get nice here in New England again.
Must be nice to live in Cali![]()
