Dizzy the 5.0 mod bug has a hold of you! May the force be with you.![]()
It's true. I have the bug myself. I have a 93 gt vert and I'm getting a new set of underdrive pulleys for 35 bucks. Alternator, crank, and water pump. I'm keeping the stock alternator pulley and only going to change the water pump and crankcase. I have an 180 degree thermostat, so hopefully, my car does not run much warmer.
haha! Nice but with 294rwhp you can be we'll into the 12's now!
My Mach 1 was running 12.1's@116mph with only 294rwhp and 312rwtq.
It's possible.
Every think of doing mods that don't add hp but remove weight instead?
It obviously helped you off the line, but you just dont have enough power, 96mph is pretty low. Losing alittle mph after gears is normal. Gears dont give you more power, they just make your wheels spin faster, which you saw help out off the line, like I said you need more power to finish it off. When you can get over 100mph and a set of slicks or dr's, those gears will be helping. And dont spend too much time in thrid, you need to shift to fourth with 3.73's, shift into fourth like you shifted into second and third. I would set your timing to about 14 and shift at about 5400 use premium gas and thatll be the best you can do till you get some more power or lose weight, the car not you.
EDIT: I kept on reading, saw you got it running good.
Sorry, Im not up to date!
How much boost are you going with? Is it still the factory block?
as for my mods incase that helps CAI, Shortie Headers, catback exhaust (still have the four cats on there) 3.73's and thats about it.
Im going to change the LED's in the cluster to blue over the weekend and ill post pics of that. Steeda didnt do to bad with that cam
114k miles on the stock clutch and its still holding that power... Going to need a new one once i start making passes i bet ;pThanks114k miles on the stock clutch and its still holding that power... Going to need a new one once i start making passes i bet ;p
Im going to take a picture right now. I think its going to look good lol... its finally dark enough to tell!
