You will need: pedals, shifter, clutch, flywheel, bellhousing, tranny, lower shift boot, 5-spd, clutch cable & fork, console plate/upper boot, i recommend installing a billet clutch quadrant and firewall adjuster before installing the pedals and cable. you also have to take your cluster out and re-route the speedo cable through another hole in the firewall because AOD cars route the speedo through the same hole the clutch cable uses in 5-spd cars. Consider a new speedo cable if your speedo is bouncy, and its a good idea to get a new speed sensor and drive gear.
i used my AOD crossmember and mount
starter is the same
do the swap, it isnt hard at all. the hardest parts are getting the AOD, converter and lines out, and installing the jumper to make reverse lights work with the T5. Which isnt even that hard. you will also have to cut the hole in the floor a little bit for the shifter to fit through.
just make sure you take your time, torque everything to spec. Take your time and you can have it done in a weekend.
