Are your current pistons notched? I might look into the AFR's over the TFS heads, since the valves on the Twist Wedge heads will be canted and may not line up with the notches in the pistons. The X303 is a pretty radical cam, so the only way to know for certain would be to test fit the heads with it.
I have the factory valve reliefs in the pistons.... I'd really like the AFRs, just have to check the PTV clearance.... Maybe I'll look into a set... what do most guys run Combustion chamber size-wise?? 62cc?? If I buy heads, I'd rather do it once.... my next motor build will probably be a 331.
Thanks
--Ryan
