I picked up a '94 Cobra back in January to serve as a nice day driver/autocross car. I didn't plan to do a lot to it but that all changed. LOL!
Here's a list of the mods I've added since getting it:
-MM 4 bolt CC plates with the following specs: 4.8* caster, 1.6* camber, zero toe
-Koni sport single adjustable struts
-MM front coil-over kit with 10" 425lb springs
-urethane rack bushings
-MM HD torque arm
-MM full length subframe connectors
-MM panhard bar
-MM adjustable rear sway bar
-MM/Bilstien rear shocks with 8" 325lb coil-over springs
-17X9 Anniversary cobra wheels with 275 Kuhmo V710 tires
Engine mods include:
-AFR 165 60cc heads
-home ported cobra intake
-1.7 cobra pedestal rockers
-new lunati timing chain
-Morpheus power pipe
-65mm TB
-FMS shorty headers
-Bassani offroad X pipe
-Summit cat back with magnaflow mufflers
-pro 5.0 shifter
-Mallory FPR set to 45lbs of FP (no idea if this is optimal, I just didn't want to lean it out under WOT)
-255lph high pressure Walbro fuel pump
I run the car in CP due to these mods. I knew I'd have to re-learn how to drive the car after adding all of these parts, but I wasn't prepared as to how different it would react in comparison to all the mustangs I've driven over the last 15 years. I have a lot to learn to say the least. Overall I'm happy with my first time out shakedown, but I need to improve a lot if I hope to be competitive.
Here's a few pics from this weekend:
-MM HD torque arm
-MM panhard bar
-AFR 165 60cc heads
-65mm TB
-FMS shorty headers
-pro 5.0 shifter
