I'm looking at a coupe and it has an aftermarket sunroof I think I want it gone because it leaks and its sealed shut. Would that be a hard task?
so should I pass on the car or think about just replacing the sunroof?
What about getting a donor roof from another car and going that route?
I'm thinking in order to install an aftermarket sunroof the roof they have to cut all the roof support out right?
Cant you run a Carfax thingy on it and see?Do you think that looks like its had a front end collision from those pics? I'm pretty convinced it had a front end collision.
Negative. My '89 came with a factory sunroof and the headliner has been gone from that car for ages. The roof support bar you're thinking about goes across right where the dome light is (since that's what the dome light mounts onto). So unless yours is some weird aftermarket hackjob sunroof where they deleted the dome light to do it, then no, there's no hacking of the roof support bar at all. The sunroof is usually mounted ahead of that area (otherwise you wouldn't be able to easily reach back to open/close it while sitting in the front).
Except on NON-sunroof cars, the roof support does run right through the middle. It needs to be cut out to install an aftermarket sunroof.
