Supercharger vs Turbo
Thats not necessarily true at all, I dynoed 428hp at only 10psi with my vortech....
You are putting much more stress on the block then I am with turbo and I made 423.12hp at 8.22 psi and you made 10 psi to do that. You got heads, cams, longtube ???? cause I know bolt on mustang only mustang to hit 400 is hard with 8psi. My cams are hurting my performance just to let you know.
I need to go back to see my tuner cause now I don't have leaks and now it's shows 8.5-9 psi. Doing cobra tank/pump with pprv delete and should be done by 28th,I will let you guys know what # I make now. For easy power and less stress on the block it's hands down TURBO.
i am at 446rwhp with my little sq-trim vortech @8psi
that turbo kits sounds good cheap as hell .....
Thank you and yes turbo spool sounds great, It's let you know power is coming :) .WOW your head/cams/exhaust and other bolt-on working really great to make that kind of power out of vortech. That is just awesome . :nice:
How is that MMR 900 block working out for you ? Once I was in love with that block and wanted one bad but still no money :(
yea the mmr 900 shortblock is holding up great
i just dropped down from a 3.60 to a 2.95 pulley and a 10% overdrive crank
so hope to see 16-17psi at 6000rpm this set-up will over spin the blower alittle
but the block is good for it.....
Just curious on how your cams are hurting your performance? Not tuned properly? I have the same and plan on going tt in the future, so just wanted to get that heads up...
