You can use a torch to heat the bottle up. I thought they were supposed to be around 1600 PSI?
n EVER REALLY TRIED MY FRIENDS ONE OUT EAITHER CAUSE THE SAME THING WOULD HAPPEN. (damn caps lock)
At around 3000 RPM the car would just fall on its face but wouldnt die. I believe it has something to do with where the system gets its fuel from as well. I think (and could be way off) that taking it from the testing port is incorrect and that the fuel adapter is needed that goes on the pressure sensor. I think all the fuel gets dumped from the fuel rail from the nitrous system before the FPS sees it and then corrects it incorrectly.
Hopefully one of the nitrous gurus will chime in.
While it was my first Nawz install I am somewhat mechanically inclined.
Yes I removed it. I even confirmed the system worked by unpluging the NOS solinoid and pressing the wide open switch at idle just for a split second and hear the car bog (idling in the garage) and spray a little fuel out.
