Electrical Nightmares...
Dugan
47
Portage Mi
Well, lets see, my brake lights stay on..always. As do my instrument cluster lights, and dome light. And now to make things worse it will not shut off...at all. Starts fine, turn the key off and it stays running. This isn't it dieseling as there is NO change in anything when I take the key out.
Are these three different problems, or do you think they are all related? What do you think is causing it?
I'm wondering if it isn't just time to re-do all the wiring, I hope not though, not looking forward to that.
It has an HEI distributor in it, and the engine is a 68 302.
Resistor wire that used to run from the original coil to the ignition switch has been replaced with a wire that delivers 12v instead of the 8 or whatever.
The brake lights have been giving me this problem for about 1 year. The dome light/instrument cluster lights only started last fall when I parked it for the winter.
It staying running has only been like this for 3 days now.
So, Let me get it straight:
The brake lights, instrument lights, and dome light stay on all the time whether or not the car is turned on or not?
It might be time to redo the wiring if it's original wiring.
But do you know if the light switch works or not. The instrument gauge, and brake lights get their power from the light switch.
I was thinking the same thing. Though it is not what I want to hear..I hate electrical work.
Yes as long as the battery is hooked up the Brake lights, Instrument cluster lights, and dome light stay on.
I thought it might be the light switch, but someone told me that it would only be the case if it were the tail lights, and not the brake lights.
Well, here are some things to ponder.
Everything to do with T/S's, park and brake lights runs through the Turn signal switch.
Instrument cluster lights run with a power feed from the headlight switch to the cluster via a BLUE/Red Stripe wire.
1) Having a WRONG Brake light switch that is mounted on the nub of a brake pedal can actuate and turn the brake lights on all the time.
Have you tried disconnecting the steering column connector and seeing what happens?
Have you inspected the wiring under the dash ?
Perhaps it is time to disconnect the Ground cable from the battery ,remove the cluster and look around at the wiring behind the cluster ?
wiring nightmare!! Blinker and gas light
i have a 87 mustang 5.0... for some reason my blinker dont wanna work.. its not the fuse cuz i changed that.. i think its something going on with the wiring but the thing is i dont know what wires are for the blinkes so i can trace them. And my gas meter isnt reading and the gas light stays on...Any one know what this can be????:shrug:
Brake lights and turn signals do not get power from the light switch, at least on a 68 or earlier Mustang. Parking/tail lights do not go through the turn signal switch. They are completely different circuits. The brake lights, even though they are powered separately form the turn signals, do go through the turn signal switch. The ignition switch is not on the steering column.
Gene
Check the fuse box to see if a previous owner had tried to rig something up. I had a '64 Falcon that had strange issues with parking lights and turn signals. The previous owner tried to "give" the car emergency flashers (which are not a requirement if the car did not have them). Also there may be something wrong w/ the ignition switch or some wires are crossed.
Wrong forum :D And did you replace the flasher?
