Idle issues with fresh motor.
1BADAOD
35
OK, I have been helping a friend of mine with his 94' GT and I am at a bit of a dead end.The car dosen't idle very well and when you take it and drive it seems a bit doggy.
Only mods to the car are ported stock heads, trick flow stg 1 cam, and C&L M/A meter. We just replaced the distributor (it died during the rebuild process) it was installed correctly and timed right. We have pulled off the IAC and cleaned along with a new TPS.
One odd thing about the TPS, the old one was WAY below specs and at WOT would barely read over 1 volt. The new one, is doing the SAME THING, very low idle voltage and very low WOT voltage. I am thinking this is the problem but have no clue why we can't get more voltage out of it........
Any ideas????
is the MA meter matched to the 19# injectors? you might try putting the stock MA meter on just to see if there is any difference....
that is weird about the tps too :shrug: was the reading at the tps or at the computer? maybe the new tps is also bad?
Voltage is being checked at the TPS.
The MAF electonics are his stock ones, just bolted to the C&L meter. The meter has the correct calabration tube.
I agree the voltage is very weird, that is what has me stumped.
Try resetting your idle and TPS with the following procedure. If your idle problem is NOT being caused by a bad part or vacuum leak then I have never seen this not fix the problem!
Begin with a cold vehicle. The idea here is to get the car to a firm cold idle with enough air bleed capacity left in the idle circuit for IAC adjustment.
The idle stop should be set first. Back out the idle stop screw, away from the bell crank arm, until about 1/2 turn past the point where it no longer makes contact (blade fully closed). Using a 0.010" feeler gauge, tighten until gauge just drags between screw and bell crank arm. Remove feeler gauge. Tighten screw exactly 1 1/2 turns. If the screw is very loose, put a drop of loc-tite or silicone on it, so it doesn't work out of adjustment.
Now remove the connector to the Idle Air Controller (IAC) just on the other side of the throttle body. Start the car and allow vehicle to warm for 2 minutes. Give a small "blip" to let it settle. If it is having a hard time staying running you may have to get an assistant until you can get to the front of the car. Now open or close the air bleed screw (CCW opens) next to the IAC until the car idles at 575 to 600 rpm. For guys with aftermarket cams and an EEC tuner, you might want to idle a bit more briskly, say 650 to 675.
Obviously, this rpm range is by what the car and driver wants...IE, no set idle speed, whatever works for YOU.
Turn off the car. Now count the number of turns clockwise to close on the idle air bleed screw. If it falls between 1/2 and 2, it's okay, now reverse it out the same number of turns. Log the number somewhere in case you need it for the future. Reconnect the IAC. You are done.
If the air bleed screw is above 2 turns, it's a good idea to tighten the idle stop screw another 1/2 turn, and then repeat the idle setting. If it is below 1/2 turn, then loosen the idle stop screw by 1/4 to 1/2 a turn, and repeat the idle setting. Be sure to put another drop of silicone RTV on the stop screw if it was disturbed. Reconnect the IAC.
Now remember we adjusted the set screw on the throttle body. That means that the voltage reading from the TPS sensor has changed. It should read between .96 and .99 volts. Anything outside of that range will cause all sorts of issues including misfires and rough idle.
you will have to back probe the TPS connector. With the connector attached to the TPS stick a paper clip into the rubber boot on the connector where the top and middle wires go into the connector. The rubber is very flexible the paper clip will slide in between the rubber and the wire.
Set your multimeter to volts. Turn ignition to ON. Then place your multimeter leads on the metal pins. If it comes up as a negative that is okay as long as you are -.96 to -.99. If you get this reading then great you are done and hopefully your issues are gone. If not proceed to step 9
This is where and extra pair of hands come in handy. Using a large screw driver you will need to loosen the bolts that hold the TPS. DO NOT USE A SCREWDRIVER THAT IS TOO SMALL BECAUSE YOU WILL STRIP THE BOLTS. They probably will be really tight so you have to really lean on the screwdriver and use some finesse.
Once the bolts are loose you will need to move the TPS up or down and continue to read the voltage. Once you get it to the desired setting you can retighten the bolts. What I do is I find .97 and then as carefully as possible I tighten the TPS down. what will happen is the voltage will change usually to .96 or .98 but that it okay. Once you are done with this manually open the throttle body a few times and close it then reread the voltage and make sure it is still within our desired range.
Depending upon how loose your set screw was you might want to cover it in RTV to hold your setting. At this point you have CORRECTLY reset you idle.
That's a good write up :nice:
For the 94 - 95's there is no TB sensor adjustment nor is there a need to adjust the voltage if it's between .65v and 1.25v. The PCM will learn the closed idle position between this voltage range. However, it would normally be around 1v. If it's at the extremes the TB sensor is likely failing.
